- May 30, 2012
- 1,628
- Plaster
- CircuPool Edge-40
This is a follow up after 3 months of use. I thought I started a thread on this, but I can only find a few postings I mentioned this bot. They sell this through Target, and 3 months ago it was under $500, quite a bargain. I throw this in the pool when I see debris on the bottom (once or twice a week). No fancy wifi or programs, just one 3 hour cycle. Worst thing that happens in my pool is acorns. Attached is today's collection. This Aquabot got every one!
If you've had the Aquabot 4WD, you'll be much happier with this one. It's almost identical, but improved filters (old ones are useable), and swivel cable! The swivel works very well. It may tangles a bit while running, but as you pull it out, it untangles. Filters are slightly harder to clean since it's cloth like (needles stick), but an extra couple minutes of hosing off, gets it all (including silt). Climbs walls much better than the 4WD.
My 4WD is still going after 9 years, if this lasts half as long I'll be happy. Will use it as spare parts should I need to.
