- May 3, 2007
- 17,066
- Plaster
- Hayward Aqua Rite (T-15)
This is the code for the filter button. See if you can send it:
100200028000800001141003
Also, with the app, see if you can try pressing one of the buttons multiple times in a row and see if it works at all. Sometimes when the timing is off, you can sneak in a command at that right time. It just might confirm it is a timing issue.
Should add the above may only work without the script loaded.
