- Jul 24, 2017
- 115
- Plaster
- Pentair Intellichlor IC-40
I replaced a seven year old IC-20 with an IC-40 about 10 days ago. The flow switch on the old IC-20 had failed and given its age I decided to simply replace the whole cell. I went with the IC-40 this time since the price difference was only about $100 and I liked the idea running a shorter interval each hour than the IC-20 required to generate the same amount of chlorine. Installation was simple and the new IC-40 functioned perfectly until this weekend. Today I noticed a red light on "cell status" indicator on the IntellipH Acid Dispenser and sure enough, the cell was totally dark, with no lights visible at all. I shut everything down, cut all power to the system, unplugged and replugged the salt cell cord into the IntellipH Acid Dispenser, and then restarted the system -- the IntellipH Acid Dispenser "cell status light" opened at green, the IC-40 lights flashed on briefly, both were encouraging, but then IC-40 went dark again and the cell status light on the IntellipH box went back to red.
Anyone have any thoughts? I replaced the prior IC-20 seven years ago too, it's a simple job and I followed the book again this time. It worked perfectly for over a week but now this. The pool is clear and clean, the water chemistry is fine except the chlorine is a little low of course. Other than that everything seems to be perfect with both chemistry and equipment. The only two things that makes sense to me are (1) I just got a bad cell, which I know is possible but statistically unlikely, or (b) the IntellipH Acid Dispenser itself just randomly failed right now, a week after the new salt cell got installed, but that seems like an odd coincidence too plus -- based on how it displays and operates -- everything about that little control center appears to be working normally.
