- Apr 11, 2021
- 74
- Plaster
- CircuPool Core-35
Hey all - I have been running a Circupool core35 SWG for ~1.5 years now.
Full disclosure, I didn't do any maintenance/checking beyond looking at the lights for the first year.
This past May, I took it out and saw there was some calcium (??) buildup on the cell, but much less than you see in this picture now. I cleaned it the best I could using a stiff nylon brush and was able to eventually remove most of it. Some chunks were still loose inside the unit though and I couldn't see how to get them out.
Fast forward to today, I went out to check and things have gotten far worse
I know using an acid solution is not ideal due to the corrosive effects on the actual plates... but I seem to be well beyond the point of cleaning this with just a brush and water.
I humbly ask for your guidance on how to thoroughly clean the cell, and also how to prevent this from happening going forward.
My guess is that I just let my pool spend too much time in the positive CSI range (pH loves to sit at 8+ and I don't add acid often enough). I thought salt cells were supposed to reverse polarity for part of the time while running to help prevent this from happening, but I could be misunderstanding this.
Pool math logs are in my signature.
Thank you in advance!
