Hi
Indoor Pool seems to have white water mold ( I think). I have been slamming for a 2 days and it seems to be getting worse in appearance but chlorine loss is going down
Details.
Pool
Build Type: Vinyl
Volume: 14200 gallons
Latest Test Result Summary:
FC: 27.5 (6 hours ago)
CC: 0.5 (2 days ago)
pH: 8.0 (2 days ago)
TA: 130 (2 days ago)
CH: 120 (2 days ago)
CYA: 60 (2 days ago)
So Saturday night it Was FC of 16. I saw some white stuff (we had just drained off 1/3 to lower the cya on Wednesday and I hadn’t read to let the hose run - now I realize that was probably the mistake that started this)
I started SLAM at 2 AM Sun morning to 28.5 FC. After 8 hours at 10am it was 26.5 FC. So losing 2 ppm in an overnight. Pool is inside so it doesn’t get UV. (Except for the UV light on the pump). Previous overnights I tend to lose about 1 due to the UV I think and whatever it sanitized.
I have tried to maintain at 28 and checked a few times and added a the recommended amount of bleach to bring it back to 28 each each time.
When I opened it up at 10pm Sunday. It has been 28 most of the day pump running on high speed. When I rolled the cover off and turned on the swim jets there was a lot of floating mold on the surface. I feel like there’s more than when I started SLAMMING 20 hours prior.
It seems like I have some mold in the swim jets as well because when I turn them on it seems to add floaters. The swim jets are basically an independent loop not on the circulation so I am wondering if the water and mold is hiding out in there and running it knocks em loose.
Starting the second overnight test on Sunday night at 27.5 and I can edit or reply in the morning once I have that result.
I guess my question is what should I be doing? Is it normal for it to get worse? Do I need to run the swim jets? How often? Cover open or closed?
Am I just impatient?
Extra details:
Cartridge filter, uv light
Was using pool store maintenance chemicals, had some white tissue paper problems. CYA was over 140. Stopped putting in CYA started using the calculator everything got better. Dumped water this week so that I can have my ppm lower. CYA now seems to be 60 or 70. Depending on how hard I try to see the dot.
Haven’t added anything except cal hypo granular and bleach for a while.
Details.
Pool
Build Type: Vinyl
Extra details:
