The two-speed pump on my 1993 Sundance spa only hums when started (on low), but will start if bumped to high speed. I'm guessing the starter capacitor is bad. But where is it? I had the motor replaced maybe 15 years ago with a refurbished one. No spa repair place in my area (San Jose, CA) is willing to touch anything this old—they can't even get a new pump for it—so, I'm trying to repair it myself.
The bump on the side of the motor contains what I presume is the run capacitor (25 μF, 370 V). I pulled the bell expecting to find a starter capacitor inside (based on YouTube videos), but see only the Klixon motor protector, and a white cut-out switch with spring mechanism on the shaft. There may be something as part of the white terminal block—can't quite see. I don't see anything that looks like another capacitor.
Does it not have a starter capacitor? In which case is the starter winding bad? Any suggestions or other help would be appreciated!
