I have a 13k gal in-ground vinyl pool salt water pool with a variable speed pump that hasnt been officially opened and does not have the salt in it yet.
at the moment, the pool installer has scheduled my pump to run at 1800 RPM for 24 hours a day. Im thinking this might be too much, but also should i run it at higher speeds at some point during the day? i have shocked it with a few pounds of chlorine + have chlorine tabs in the skimmer.
question for you:
1) whats an appropriate schedule to run (assuming salt chemicals are in and pool is officially opened)
2) when should i do high speed, low speed, and off?
question for you:
