- May 23, 2015
- 25,114
- Plaster
- Pentair Intellichlor IC-60
Today was a case of the sadz for me ... my IC60 appears to have moisture escaping from the seem under the top cap that holds the membrane pad. The electronics and membrane pad are potted into the top of the PVC body and thermally sealed. It’s not a great design. I was out there a week ago and noticed a salt crust around the edge of the plastic sun shield. I wiped it clean but it came back. On top of that, one of the union nuts is cracked. I have spare unions, but that means PVC work to fix the cracked nuts. Some pics -
The bummer is the unit is only 4 years old and I paid just around $990 for it back in the day. A new IC60 so far is $1800. Gotta love COVID-flation ...
So far nothing is dripping or spraying water. The nut is holding for now. I plan to get a replacement split-nut for the coupler to avoid PVC pipe reworking. As for the cell, the option is either do nothing until it springs a solid leak OR clean up that entire edge and seal it with RTV or Epoxy. Sealing it might drive whatever water is weeping there somewhere else and considering the electronics under there that will probably result in a short or some other electrical catastrophe.
The sad part is the cell is generating perfectly fine, lots of life left on those plates. So when it does finally let go, it'll be a premature death.
More info to follow ...
