- May 23, 2015
- 25,681
- Plaster
- Pentair Intellichlor IC-60
Nice rebar!!
Ok, so that first picture is the high-flow air-relief valve (I have one just like it on my DE filter). If you grab the plastic cap just below the gauge and turn it 1/4 turn counter-clockwise, it opens the air relief valve and then water will come shooting out that opening. There are two rings in the valve that make the seal when the shaft is rotated and I would bet, if water constantly dribbles out, that one of the sealing surface either has some little bit of gunk on it OR the o-ring may be bad. Either way, it's super easy to take apart and fix (I did it once) and extra o-rings can be purchased at any ACE Hardware store (or HD or Lowes).
The dribble from the body of the filter bothers me more but is very likely just large rubber o-ring that seals the two halves together is either off a little or the collar clamp wasn't tightened enough. The plumber may have put it together hastily and it could just need to be lubed properly and reseated. Again, probably another quick fix.
