- Jun 12, 2023
- 167
- Plaster
- Hayward Aqua Rite (T-15)
So I think my paralevel automatic water leveler has problems and isn’t working right. A month or so ago my pool water seemed like it was lower than it should be and I felt debris wasn’t skimming well because of the water level. So I adjusted the paralevel and turned it counter clockwise in the direction it says you need to turn to raise the water. Doing so did nothing to ameliorate the problem and water got lower and lower until my skimmer basket had no water in it and air was getting sucked in. Pool company that works with PB said to manually add water to
Pool. I did and added a little too much. We adjusted the paralevel (which was at the max height from before I added the water) . Lady from
Pool company said it looked like it was at the perfect height, but now the water is getting low again. Should I turn the paralevel again? I did one revolution so far .
