Katodude
- Aug 22, 2017
- 2,991
- Plaster
- Hayward Aqua Rite (T-15)
just going to throw this out there, but I found a product years ago that was suggested to treat for insects and what not. Also found it worked great in a backpack fogger set up when spraying for mosquitos. It's called Bifen IT. Since I began using it, I've found it works well on just about everything. I spray ant beds with it and it works better than anything else I've tried. That being said, I've used it on several wasp nests and it works almost instantly. If I find a nest hidden in a bush, I spray the whole bush. It'll kill anything that lands on it for a while. Just buy a cheap one gallon sprayer and mix it up. Cheaper than buying all those other products at the hardware store and has several uses. I even fired all my pest control services and spray the house myself now. Haven't had a single bug issue in years. Here's a link if you want to check it out
Amazon.com: Bifen IT Control Solutions Insecticide Concentrates: Gateway
+1 in on the Bifen. It is fairly cheap and you can apply it with a pump sprayer around your yard. Coupled with the other things you are doing it should help a lot. You have to re apply after it rains.
