I recently replaced the pool liner on my steel wall above ground pool. We had a massive leak over the winter and lost all of the water in the pool, which caused some bowing in the wall in a few spots. Now that the new liner is in,and the pool is filled, we have two uprights beside each other that are sitting incorrectly. One is about an inch too low, so we cannot screw in the top plate. The other is not sitting flush with the pool wall. I'm not sure how to safely reposition them, and could really use some advice. I'm praying that we don't have to empty the entire pool to fix this problem.
Thank you in advance for any and all help!
