- Apr 13, 2022
- 91
- Fiberglass
- Pentair Intellichlor IC-20
Ok. I know the general consensus is not to trust the pool store test results, but I feel like I need to ask for my own sanity...
I have 2 different drop based alkalinity test kits and a ton of different brand strips. One alkalinity test is in the TF kit I have, and the other is in an HTH 6 way test kit. I have tested multiple times over the last month or so and I'm always around 90-110 with both testing options. Even the dip strips give me a number in that approximate range. I was slowly working my way down from initial pool store results when we opened in March that were around the low 200s, and I was happy to be right around where I thought I needed to be. Then I went in the pool store to grab a vacuum head, and decided to take some water with me to get tested. Their TA reading was 22.
They told me that was TERRIBLE, and I asked them to check again. They said they got the same thing. I went home later that day and tested again with both the TF kit and the HTH test. I got 80 with one and 90 with the other.
I'm assuming that I need to just ignore the store, but it's SO completely different. Why would their test be off so much if it is the one that is wrong?
For reference, everything else was fairly close that day. The other differences were in CYA (me-30, them 17) and CC (me-1, them 3.6).
