In case you didn't see my post in the "Opening the pool", I discussed how last year I had a single spot where a piece of nut sedge grew into my pool liner. I "cut off" the nut sedge and injected roundup into the sand and thus killed it off, also patching the spot where it grew from. Unfortunately, my patch seems to have not done the job and as of the beginning of this year I noticed a large drop in water level from the closing last year. The pic below shows the patch and you can see how it appears to be pulling up/off.
My questions are simple:
1. Anyone have any tips/tricks for patching that spot/bottom of the pool liner?
2. Is this a good pool patch kit instead to get? Amazon.com
The original patch that I got was basically from Walmart and I believe it was probably cheap and just not good.... I just need something high quality that will last. If you have any suggestions on what patch to get or how to fix this please let me know!
