I am at my wits end. Last year we bought this home with a 20x40 inground saltwater pool. It had not been opened at all last summer and in late sept we had to open it for our home inspector to investigate prior to us making an offer. The home inspector was trained in pools and gave the pool a good inspection. Once we moved it, it was almost time to close the pool. My daughter and son both complained of feeling shocked when getting out of the water. Long story short, we were reading as much as 4 volts in the water. Called electricians who had no answers and also contacted the utility company. The utility company turned off all power to the entire subdivision and we still showed voltage. They added additional grounding and the levels dropped to below 1 volt. You can really only sense it if you have a break in your skin somewhere from a cut. We are still reading 0.2-0.4 volts with all power off and I am just scared to death of this and want it fixed. I have called another electrician out and he has no solutions. Talked to the utility company again and they suggest it is a problem with our bonding wire. There is a copper bonding wire and the original owner says the concrete deck is bonded. If you are touching the concrete deck and it is wet, then you touch the water with your other hand you get a tingle. I have called multiple pool companies without anyone who seems to be able to help. I’m scared for my kids or other family to use it. Any suggestions?
