I have been looking everywhere for a threaded water temperature sensor (10k ntc thermistor) or where someone has done this already. I’m googled out.
The big 3 make sensors where you have to drill a small hole in the pipe and then use a saddle clamp to hold the sensor in place (no threads)
Since I am rebuilding the equipment pad and not retrofitting, I want to use a 2"s X 1/2"fipt X 2"s tee such as this.
Then just wrap the temperature sensor threads with some teflon tape and I’m in business. Makes replacing the sensor down the road, much easier as well.
I can’t imagine someone has not thought of this already, so if you could please share, that would be great. Thanks in advance!
Also, I'm going to ask another dumb question. Since I will be adding an IntelliChlor with automation, and since the Intellichlor measures temperature I believe. Is that temperature from the IC relayed to the automation or do I still need to use a separate water temperature probe?
