threaded male connector on pump won’t stop leaking
ForceEdge
142
Long Island
CircuPool RJ-60 Plus
Attached it below. I can’t get this darn thing to stop leaking. I usually go around the thread male connector 5 times, two rows with Teflon and it still keeps leaking..any ideas on how to resolve this?
I can’t stand even seeing a small leak so it’s bothering me so much hah
any ideas would be much appreciated
Is there a union on the pipe so that you can tighten the connection more? Have you bottomed out the connection against the flat shoulder? Normally the connection doesn't bottom out before it's tight. Perhaps try a new threaded connection and see if you can tighten that without bottoming out.
It’s pretty tight. I used the white Teflon tape, and I can’t turn it anymore because at the top of it is a 90 degree fitting that goes into my multi port valve and I can’t spin it all the way around again without worrying of Damage :confused:
Is there a better Teflon tape I could try or should I put more? 🤷‍♂️
More teflon tape isn't the solution. Your original statement of using 5 turns should be more than enough.
I would go to the store and get a union and add that between the pump and the elbow. Also pick up a new threaded connection and a short piece of pipe. These are available at most big box stores. If it was me, I'd use the new threaded connection and the union to start over. The union will help you later in life if you need to change out the pump.
Edit to add link: PVC glue union
I have a Union after the 90
alright I’ll grab another threaded connector and try that out. Will let you know how it goes tomorrow.
thanks for the advice!
FE,
I never install a pump without using pump unions.. No tape or glue needed..
What you have is NOT a pump union...
Pump unions have an O-ring on the threaded end that screws into the pump.. the O-ring is what keeps it water tight.
Wow. I never even knew they made a threaded pool pump Union with a rubber gasket like that. I feel dumb.
So that’ll definitely stop the leaks because of the gasket right?
thanks so much. You think a pool store would have that?
FE,
Just wanted to reach back. As you can see, problem has been solved. Thanks so much my friend! Appreciate the continuous advice
