I would like to reinforce my Jandy check valves and 3-way valves so that they have a longer service life, especially the ones that I have installed 24VAC actuators onto. I am considering trying to swap the factory coarse threaded screws for a stainless threaded insert and machine screw. Has anybody tried this, or perhaps even had to resort to this to make a repair to avoid plumbing in a new valve? Valve replacement is not only time consuming, but existing plumbing can only handle so many PVC couplers before you run out of options when doing retrofit work. Here is what I am looking at using: Insert # 632J14-18SS | Yardley Inserts Self-Tapping Insert. Has anyone tried this?
