- Jan 5, 2023
- 75
- Plaster
- Astral Viron V35
I am in a few facebook groups for pools and a few other pool based communities. One big difference I see between them and TFP is the use of algaecide, specifically copper based ones.
www.troublefreepool.com
The arguments presented are that they are simply not needed, and can stain or damage your pool. This is easily refuted, as just because something isn't needed doesn't mean you can't derive benefit from it. You can also easily limit the use and keep levels within range to avoid staining, as only chronic use will cause these things to happen.
The best argument against the use of algaecide is actually very simple. If free chlorine levels are not high enough to prevent algae then it won't be high enough to kill pathogens. You can kill the algae but it will not kill the pathogens. Whilst there is no algae you will likely have no visual incentive to increase free chlorine to adequate levels.
This is something seen on this forums fairly often (IE a clear pool is not a sanitary pool) however it should be the primary reason for not using algaecide - its inability to sanitise a pool - with the other reasons being secondary to this
Algaecide - Further Reading
Non-Recommended Pool Chemicals
These pool chemicals should not be added to your pool. Save your money and frustration and avoid these chemicals!
