Tft100 vS hach pocket colorimeter II
0.4ppm. It’s a low end measurement so you’re not that far off. And you need to be really accurate with your water sample size.
I would be more inclined to believe the colorimeter is not acting linear on the higher end. Colorimeters are usually only linear over a fixed range. We have seen no end of problems with digital testers and water analysis. Trust the chemistry and not the colors …
Thank you! I just diluted the pool water and the readings were the same. It does seem to be an issue with only the higher readings.
