I’m on day 2 of using the TFP method, and am seeking help for keeping my pool’s chlorine level where it should be. What I’m learning seems contradictory.
Concerns:
The TFP-recommended TF-pro kit comes with a Taylor 9781 comparator block that measures chlorine levels up to 5ppm. However, according to the app, an ideal CYA level is 45 which means the chlorine range should be 4-8ppm with a target of 6ppm.
The TF-pro kit’s included instruction card say to test chlorine daily using the comparator block. This is seemingly impossible given the block doesn’t test chlorine that high. In practice, my CYA is higher at 60(ish?) so that makes following that instruction card even less feasible.
My Questions
How often do you measure chlorine and what testing method do you use? Why does the testing kit include instructions and materials for daily chlorine below TFP’s target levels? Ultimately, am I misinterpreting the TFP method as it relates to chlorine?
Thanks!
Pool details: 15,000 gallons, plaster finish, Phoenix area, using liquid chlorine only for the last 2 days.
Concerns:
My Questions
Thanks!
