- Sep 23, 2015
- 1,998
- Plaster
- Astral Viron V25
Oops, my bad. I thought they were the conversation factors. Taken from the manual. But they are the temperature compensation coefficients, in %. And it’s a simple application, the compensation coefficients are applied when the sample is above 25dC.Can you explain this better?
Conversion from what to what?
It's a nonlinear function for the graphs, so you cannot have a single conversion factor.
The manual doesn’t actually give the conversion factors but implies there are three, one for each mode, 1314, 442, and NaCl. EC to each mode.
Probably a bit confusing but the conversion factors for my meter are given as non-linear. But from memory it’s not a true non-linear conversion but rather two linear factors with a transition point set quite low.
From my home testing, it showed that a calibration point above the read value is slightly better then a calibration point below.
All this highlights the problems associated with a single point calibration meter but if done properly they do work and maybe a viable alternative to the drop test, especially when you consider the broad range of the SWG. Although from what I can tell the Aussie SWG have a broader range then the US ones. Note the results of the test strip, at 5000ppm they were out by ~400ppm but not too bad at 4000ppm. Having said that I don’t use then and the ones I tested were the capillary type not the colourmetric.
I went with the HMDigital because it’s variable calibration as apposed to the Apera Salt20 with a single calibration point at 5000ppm. But 5000ppm works fine and the Salt20 is probably a better meter. Just need to make sure that a decent 5000ppm calibration solution can be found. If I get another meter I believe the Apera EC60 has two point calibration but at 1413μS/cm and 12.88 mS/cm, which are harder to find.
