Sylvania 250W LED bulb
Hi Kaminski54,
The base on that bulb should work as it is a E-27 thread in base which should be comparable to your current base. The big difference will be the diameter of the bulb as the PAR38 bulb is 4-3/4" in diameter where normally for a pool light you will use a PAR56 bulb which is a 7" diameter bulb. This bulb should work but it will not be as bright as your current bulb because it is quite a bit smaller and has a lower lument rating, but it is worth giving it a shot. If you wanted to go with a mid range LED in the $150 range rather then the $400 range then you could try the PureLine PureColors LED Color Changing 120V PAR56 Bulb.
Hi Kaminski54,
Awesome. Thanks!
