- Dec 26, 2021
- 6
- Fiberglass
- Hayward Aqua Rite (T-3)
Greetings TFP-
I have a Hayward Aquarite T3 SWG. We ran our pool throughout the winter and did not add salt in the spring. SWG has been showing 2200-2700 ppm since February. I last cleaned the SWG and replaced Hayward Swim Clear filter in March, but this did not resolve the issue. I purchased a new Taylor K-2006 Salt test kit this spring and test results from today are below. It does not appear additional salt is indicated based on the test kit results, yet the SWG keeps flagging for reduced efficiency or stopped chlorine generation due to low salt ppm. FC seems to be adequate though it is not generating.
I am thinking the SWG needs to be cleaned again (diluted MA or just fresh water if no scale), or the inline sensor needs to be replaced? Our pool was constructed in late 2020 and I hoping the flow sensor does not need be be replaced already. Any thoughts on why the SWG is showing inaccurate results?
Blake
Results from today:
FC 6.0
CC 0.0
pH 7.6
TA 75
CH 350
CYA 80
SALT 3400
W_Temp 81F
A_Temp 79F
CSI -0.27
SWG 2200 (@50%)
Blake
Results from today:
FC 6.0
CC 0.0
pH 7.6
TA 75
CH 350
CYA 80
SALT 3400
W_Temp 81F
A_Temp 79F
CSI -0.27
SWG 2200 (@50%)
