JI have an in-ground pool and the handrail is stuck. It uses the wedge anchors that has a bolt to tighten up the wedge to hold. To remove the handrail, loosen the bolt and tap the bold down to release the wedge. One of the wedges has caulking material under it preventing the wedge's ability to release enough to remove the handrail.
I've tried using a tractor jack, a scissor jack and it will not loosen enough to remove and I am bending the handrail. I am about to cut it with my reciprocator saw and If I do should I leave some of the pipe sticking out so I can clamp the rail to it?
Unless there is anything else I can do before I cut it.
I've been wondering if heating the area with a torch would work? Any ideas?
