I purchased a 20ft (6500 gal) Summer Waves pool last summerand like a newborn child it came with no instructions on how to take care ofit. Pool came with over the wall pump that uses cartridges, and for the beginningof summer it was great water was clear, and other than cleaning debris I had notrouble. By mid-summer I was pulling my hair out and ready to give up. Waterwas cloudy, I was changing filters every other day. I do not have a fancy testing kit (I usestrips) so I ended up taking water samples to local pool shop only to spendmore money on chemicals than what the pool cost. On opening pool this year wedrained water and cleaned liner with bleach and water. We filled pool (May 9th)and waited 24 hrs before testing, the water is clear, however when I testedwater my pH and alkalinity is off the chart high and showed no chlorine level.I added 16oz of MA and again waited another 24 hrs. (pump running) On day 3 Iget in pool and vacuum debris and wait to test in the afternoon, test showedhigh pH and alkalinity no chlorine so I added a lot more MA. At thispoint I had added no shock because I had read that if pH was high it was no usein shocking, but I waited for an hour (sundown) after adding the MA and addedshock which was supposed to be fast dissolving (pump running). This morning Itested and results are still high pH and alkalinity with a low chlorinereading. Oh and I can see some shock settled on bottom of pool. My water isclear but I know it’s just a matter of time before I lose that. My finance isconvinced that we need a better pump and not that I don’t agree, but which onethat will not break the bank and work efficiently. I am a little OCD (he says alot), so I’d like a pump that could function a good vacuum instead of the one Ihave that has a little white bag collecting debris from the water hosesuction. As far as chemistry goes I havenot the first clue on what to do to prevent my pool from getting nasty, howoften to shock, add algaecide, clarifier or any other chemical. I don’t want toget into the let me try everything on the market again this year only to bedisappointed with results. Any sound advice would be greatly appreciated.
Thanks in advance
Thanks in advance
