- Jul 26, 2022
- 250
- Plaster
- Pentair Intellichlor IC-60
Voltage is correct.Is the voltage selector correct?
Is the hose swivel underwater?
You should put a valve on the output to control the flow.
Hose swivel is not under water. I am connecting directly to the suction side of the pump. Now that you mention it…I bet air is leaking through the hose swivel. Should I be using a different set up or different hose? See pic for how I currently have it set up
What type of valve do you suggest? Like a normal ball valve?
