UPDATE: I just called Spa Electrics and they have just released a special version (R10H) that is designed as a DIRECT replacement for the colorlogic WHEN used in the shallow niche (LFGUY1000). Further, they can update the color sequence to be controlled by Omnilogic controls if you desire. I just ordered two.
R10H for Hayward Shallow niche only
R10 for any other niche
I can across this light recently while looking for an alternative to the Colorlogic 2.0 lights at $1250 each! It seems retrofitting niches with new LED lights can be a major hassle and the cost of them is atrocious.
Anyway, the R10 light has an ingenious built in adapter ring to fit a wide range of niches. Once the ring is installed, you can just pop the light module it. Another cool feature is that you use your EXISTING cable and adapt it to a plug they provide. If the light ever fails, just unplug the cable from the back of the light and replace. It looks good too and is UL listed. $600.
I don't have it yet as I'm trying to determine if this will fit in the SHALLOW Hayward LFGUY1000 niche. It looks like a slam dunk for any other niche.
Retro R10 — Spa Electrics Inc.
FWIW, the new hayward colorlogic 2.0 also has a plug end system, but for $1250, I would expect a 10 year warranty!
