- Aug 4, 2008
- 47
I know there are energy savings with Variable Speed (VS) motors but I'm pretty sure the purpose of the Spa Booster pump is to run at a single speed (3450). Does it make sense to replace it with a VS motor if I'm just going to set it to a single speed? I suppose I could take advantage of the variable speeds, but it seems unnecessary for its purpose as a spa booster pump.
The current pump is a Sta-Rite Max-E-Pro P6E6E-206L. It has a 1.0 HP motor with a 1.65 SF (with a 48Y frame). The replacement Pentair motor is AE100EHL and I believe the replacement Century (AO Smith) motor is the SQ1102. However, from what I've read, I probably can't get a new single speed replacement motor in CA. If that's the case, other than refurbishing the motor, is a variable speed motor my only option for this booster pump?
If a VS motor is my only (or best option), which one should I get to be able to take advantage of the variable speeds through automation. I have a Pentair EasyTouch 8 with the latest Firmware and a Screen-Logic Interface. The EasyTouch seems to be able to support two Intelliflo/Intellipro pumps. I already have one for the main pool/spa pumps so there's room to add another one.
With all that said, what motor would you suggest I get to replace the Pentair AE100EHL motor?
