- Aug 15, 2024
- 47
- Plaster
- Pentair Intellichlor IC-40
Happy Thanksgiving! Thought I’d add some flavor to the title.
I have the pentair intellicenter with a calimar automation panel upgrade for the calimar pump. I have one of the relays on the intellicenter wired to the solar heater relay socket which calls the pump to get to a higher speed to get adequate flow rate for the panels on the roof.
Lately, my pump has been cycling back and forth between its normal speed and solar heater speed every 1 second. There is a clicking (relay closing and opening type clicking) that accompanies that. This might be because of the temperature difference just happens to be hovering at the set temp. For example pool water temp is 73F, and solar panels are seeing 77F and the heater controller is set at a delta of 3 or 4. When the temperature difference between the pool water and the roof is much greater than four, everything works fine. Here is a link to the video showing the cycling
I recently got a pool cover and have the (possibly unrealistic) hopes of getting the water in the 80s and swim in the fall/early winter in so cal.
Anything I should worry about or just set the temp delta to much higher or simply turn off solar heater?
