Solar covers - worth it?
wayner
959
Toronto, ON
Jandy Aquapure 1400
When I was growing up we had a swimming pool and bought a solar cover (this was around 1980). We didn't have any sort of a roller so we had to manually pull it off and fold it up at one end of the pool - this took up around 4-5 feet of deck space.
Five years ago I moved to a new house and had a pool put in. We didn't get a solar cover and I am now wondering whether it is worth getting one. I don't have a ton of deck space so I am not sure where it would be stored. Obviously having a solar cover will reduce heating costs but is it worth the hassle and cost, assuming that I put in an automated roller system. The other system is that my pool is somewhat irregularly shaped and looks like this:
Code:
     ________
____/       |
|      _____|
|_____/
Here is what I see as the pros and cons:
Pros
Save money on heating
Less water and chlorine evaporation (chlorine doesn't really matter since I have an SWG)
Prevents debris from getting in pool
Cons
Upfront capital cost
Takes up deck space
Unsightly
Hassle of putting it on/off before/after using the pool
Interferes with Kreepy Krawly?
Do I have this right? What is the opinion on everyone here on whether it is worth it or not?
FYI - I live in Toronto, ON and the pool is generally open from mid/late May to late Sep and I generally keep the heater at about 85F. At the beginning/end of the season I often only heat the pool for the weekend. My heater is NatGas.
The thing that the cover will do is help with heat loss due to evaporation. You'd be surprised how much heat a pool loses that way. In my opinion it's definitely worth the cost and effort to have a solar cover.
I might move the one about the debris into the con list because my experience has been that while the debris does collect on the cover, it is difficult to get off without dumping at least some of it into the pool. But nothing a little pump run time doesn't clean up. Plus since I have a SWG, salt seems to collect on the cover so I need to hose off the cover periodically which tends to dump dirt into the pool as well.
But taking it on and off is not so bad. I use a homemade variant of the Solar Roller and it is very easy to get off and just a little more difficult to get back on.
The best part is that it cuts the heat loss in half which means I can run my pump half as much with solar which is a pretty big savings. I can only imagine it is even larger savings using NG.
With NatGas heating I would think that the costs savings with a solar cover tip the list to the "pro" side fast.
I agree with your list - our solar cover keeps in a LOT of the heat overnight but I despised the way it looked and hated taking it off and putting it on. We had spent a good amount of money on water features and lights - which I really like when sitting by the pool at night. With the cover we stopped using them.
The cover did not interfere with our suction cleaner.
As soon as the solar could keep up without the cover here we folded it up and put it away.
btw - I have seen "solar pills" which is a liquid that will float to the top at night and hold heat. People say they work, but I did not like the idea of yet another chemical in my water and they do need to be replenished. So we never tried it. The solar guy said he'd give us one for free if we wanted, but he also admitted he does not use them on his own pool...
Yes, I would think that it would reduce the amount of chlorine that sublimates, but I don't know that is much of an issue other than turning down the percentage on my SWG which I don't think really makes much difference cost-wise.
Sounds like the consensus is that a solar cover does help quite a bit... what is the best cover? And if it is installed in pieces (irregular shaped pool) with some gaps, does it still do about as well?
Our pool is irregular and asked the guy who cut the cover for us to piece it. He said it was better done in a single piece, that multiple parts will slide across each other when the returns come on. Our pool is small enough that we could get one big irregular cover cut from standard roll stock.
I'll throw in my $0.02 on this subject. I have a freeform pool and had to buy a much larger rectangular cover to cut to shape. I calculated that roughly 33% was thrown in the garbage. We cut it in two pieces for easier handling. It definitely helps with heat loss and our heat pump works better. But, I find in to be a PIA to put on, take off and store. I also would rather see shimmering water than bubble wrap and don't use it that much. I opened the pool a couple of weeks ago and may put the solar cover on when we get closer to swim season to get the pool warmed up.
Reactions: pb4uswim
My wife and I had a drink by the pool last night before bedtime (it was one of the first warm nights here) and we were discussing a solar cover. We are leaning towards no because we thought it would be a disincentive to use the pool, like have a quick dip before bedtime would become a hassle as you would have to take off the cover. I know it can save you a decent amount of money, but when you figure how much you spend on a pool in terms of capital and ongoing costs (I am guessing that my costs would be around $15k/yr assuming a 20 year life for pool & landscaping) then the opportunity cost of not swimming is also quite high. So maybe a solar cover takes the annual costs (including amortized capital and annual operating) down from $15k to $13.5k but is it worth it?
Yakiman said:
That solar roller looks great, and expensive! How did you make one yourself?
I had purchased one several years ago and it worked fine except for one thing. The aluminum tube that comes with it lasted only about 3 years before it corroded through, probably because of the salt. So I replaced the aluminum tube with 1 1/2" ABS pipe. ABS is nice because it has a foam core and floats so it helps keep the cover from sinking and the aluminum had a tendency to sink in the water. PVC sinks too. Anyway, I only had to drill a hole and notch the abs pipe to allow for the locking fasteners to work (second item):
http://solarfactory.com/solar-cover-rol ... parts.html
There is no longer a crank but since the pipe is a good size diameter, it is fairly easy to turn by hand. It makes taking the cover on and off fairly easy. So if you wanted to make one, you only need the ABS pipe and the locking fasteners.
If I get a chance later today, I can take some pictures.
I completely agree, this was our experience. I called our cover the blue pool condom.
In our case, not only did we skip the quick dip after dinner, we skipped turning on the lights and water features during dinner. However, our cover was not so expensive and since it does help get the temps up during the cooler parts at the start/end of our (very long) swim season I guess it may have a role to play.
wayner said:
I didn't think Florida had a swim season!
It depends on what water temps you consider "swimmable"... I've seen Canadians swim unheated pools at any time - in fact if you see a person in an unheated pool in January the odds are good they are Canadian (or Nordic).
For us thin-bloods... December and January are iffy with a few months around that as the "start" and "end" of the "season".
I can't say I know for sure though because we have not had our pool a year yet. For my wife, even now with the solar on... a cloudy day will drag the water temp down to low 80's and she won't go in!
I guess Lake Nona is not south Florida so that is somewhat different. But yes, since our summers are limited in Canada we take advantage of whatever swimmable time we have. Swimming season for me begins today as the air is around 20C or 70F and the water should be at 84F.
LN = Orlando, so yes a few hours of "cold" occur here on occasion - and it makes the news! (still amuses me)
yep 84F is swimmable to me too, the wife prefers 88 or more - it's 92 at the moment.
