Solar Cover + Liquid Solar Blanket
As a substance that floats on the water, I'd imagine the bulk of the liquid solar cover would be trapped in all the bubbles when you roll up the solid solar cover. It's not like it would step aside to not be in the way, then swim back to coat the pool surface again. 🤷‍♂️
For lack of a better analogy, make believe it was vegetable oil. Some would wash off the cover and stay behind, but alot of it would go with the cover.
Reactions: cledee
Ah, I see. I was only asking since I have a bottle of a liquid solar blanket that's brand new, so I wanted to use it up. Also there's a small portion of my pool not covered by the solar cover by the shallow end between 5-10% of the pool. So I figured adding the solar blanket would help with that portion of the pool.
