Hi There,
Introductions: We're a family in NZ with a small vinyl pool since we moved about 5 years ago. Took a while but I had come to an understanding with the pool, the pH tended to go up and Alkalinity tended to go down absent treatment...so adding dry acid and some baking soda every so often balanced it out. We use liquid chlorine, with multi tabs for the CYA in the summer (now!).
We got a solar cover before christmas and the chemistry has changed somewhat: Initially pH was far more stable and fewer chemicals were required. Taking a pool sample to Pool Doctor yesterday had pH 7 and FAC over 10! Without having added much recently. What's more they said phosphates were a high (never happened before) and gave / sold me a phosphate reducer (lanthanum Cl) although water has been consistently clear lately).
Adding, this LaCl has now produced a slight cloudiness which is annoying! Not super milky just a slight cloudiness too small for the filter...so I added a small amount of clarifier I had lying around and ran the pump for a while. Have also pulled the cover off today to see if the pH comes up a wee bit from outgassing...
Still a little cloudy. Looking forward to joining this community, fixing this pool and relearning it, and teaching the pool store whats what!
Cheers
Cameron
Cheers
Cameron
