Hi All
New to the forum and relatively new hot tub owner.
I've been using std dichlor for the past 3 months and the CYA builds up pretty rapidly when there's 4 people using the tub often. So decided to try out the bleach method as described here.
I've done extensive research and thin unscented bleach in a decent percentage is more or less impossible to find in the UK. So i'm looking at sodium hypochlorite. The strengths available are 10/11% or 14/15%. I think i'll go with the 10/11% due to having slightly more control over small volumes.
My question is, there are several versions with 'calgon' included. Now to my mind Calgon is a water softener to reduce limescale. Our water is a touch on the hard side at 260ppm. So would this be a good idea to use following the bleach/dichlor method?
Thanks Chris
Thanks Chris
