Soake brand pool under construction
I really like your pool and clean lines. Have any teens said they could jump it lengthwise yet? Seems tempting.
I haven’t found the size to be an issue at all. I was worried about this and it’s plenty big. Winter has been great so far with it. Fun swimming with snow flying in the air
How did you go about finding a builder to install one of these? im very much contemplating doing something like this as I continue to run into issues trying to get a larger normal pool put in my back yard. Also if you don't mind me asking what was the overall cost of this? If I went with a smaller plunge pool design id need/want to throw some money at hardscaping and landscaping to tie it all in.
also is it small enough to heat it up to 100 degrees like a spa even in colder temps?
Soake should be able to suggest an installer in your area.
Yes you can heat it to 103 if you wanted. We keep it at 92 in the winter and it’s been great so far. Heating cost hasn’t been too bad in a cold December in Michigan.
Reactions: TX2OBX
