SLAM questions
Hchang
Active member
Sep 1, 2020
39
Austin, TX
I started the slam process yesterday bcs the pool was turning a little green and recently have noticed some yellowish stuff on the walls and corners that easily brushes off.
Some background. I’m in central Texas and we just went through our yearly pollen bloom where literally everything outdoors is covered in a fine yellow powder. Keeping the pool clean and debris free is a daily challenge around this time of year. I have to clean out fully packed skimmers (tree pollen debris) twice a day for a couple of weeks. Glad we are past that now!
Also this pool is severely affected by ASR. This is likely our last season with it. We have cracks everywhere, hot tub hasn’t been able to hold water for two years. Just trying to keep the pool going for at least one more summer for my kids.
I’m following the SLAM protocol page. Removed debris. Brushed everything. Etc.
When I started yesterday:
Chorine was 0.
CC was also 0.
pH 7.5
CYA 50.
Per the calculator sLAM level for chlorine was 20.
Put in chlorine and it resulted in chlorine level of 32. Kept it above 20 all day (only had to add once). And had no chlorine loss overnight.
Water was cloudy and could still see a little yellow in a couple of spots this morning. Brushed it. Vacuumed some new tree debris off the bottom and ran the robot vac.
But now there is a fine debris all over the bottom of the pool. Kind of powder like but you can’t feel it. It’s kind of a tan color. I assume this is dead algae? When we brushed this morning it stirred up and made the water cloudier.
My pool vac (robot) does NOT pick this up. We can see evidence of this stuff in the pool skimmer socks. My biggest question is how to get this out of my pool? Am I expecting all of this to go through the filter?
Likely.
Brush and filter. Clean your filter when your filter pressure rises 25% above your clean filter pressure. It'll get it. Keep running the dolphin to keep the dead algae in suspension for filtering.
Reactions: Bperry
