My pool has two skimmers and two main drains. The skimmers have two holes in the bottom, and the hole closest to the pool has a flap and seems to lead to a nearby inlet under the water line.
From searching TFP, I gather that this is an "equalizer" to guarantee water flow to the pump inlet if the water level drops below the skimmer -- although the flap is usually closed.
My question: I maintain the pool myself and am going on a two week trip in March, around the time when live oaks drop their leaves and the skimmers have to be emptied twice a day.
Is one purpose of the "equalizer" port in the skimmer to guard against a leaf-clogged skimmer? If I open the "equalizer" port, will the pump (a Jandy VSP pump) be able to avoid sucking in air? As I mentioned, there are two main drains and two skimmers. Or would it be better to just close the skimmer valves on the pad and just do without skimmers for two weeks? The water will still be well below 60 degrees and I have a robot that zips around the bottom of the pool, but it might fill with leaves too and maybe not keep the main drains clear.
Thanks!
Thanks!
