Privacy Statement |
Privacy Statement |
Thank you. A local pool store tech had told me that I should leave the pool uncovered for a few hours after adding liquid chlorine, so I assumed that the same would be true when adding chlorine via the SWG. Is there a basic difference between the two methods? Isn't the chemical reaction that generates the hydrogen gas the same, either way?Welcome to TFP.
There is no problem keeping the pool covered while running the SWG.
The hydrogen gas a SWG produces is not a problem.
Manage your pool cover the same way you did before the SWG.
OK, that makes sense! Thanks again for your help.Addition of Liquid Chlorine adds a lot at one time and causes carbon dioxide gas to be released. With a cover on the carbon dioxide will stay in the water and can increase your TA.
Chemical reaction is very different. The SWG separates the hydrogen from Oxygen that make up water (H2O) when converting salt to chlorine.
SWG How It Works - Further Reading
www.troublefreepool.com
The hydrogen gas will find its way out of the water with the cover on.
