I am installing a Hayward sand filter which holds 700 lbs of sand. Should I add a layer of pea gravel?
What does your filter's manual recommend?I am installing a Hayward sand filter which holds 700 lbs of sand. Should I add a layer of pea gravel?
I put 4000 lbs 2 sizes of gravel & 4000 pounds of #20 silica in a filter last week...
That must be one big filter. I'll bet you don't need to backwash often.
Poolguy, if you didn't put any gravel into the municipal filter, how much sand would you then install? Basically looking for the ratio of pea-gravel to sand. however, since the muni one is much bigger than what the OP, does the ratio go up or down for the size of the sand filter re how much gravel you would install?
One person asked why install small stones? I assuming it displaces the volume of sand the filter would otherwise require, which is probably over time a cost savings. However, does the less finer material impede the ability to filter better? It would seem like the resistance to the pump would be somewhat less that would reduce the pressure gauge of the filtering system, yes?
