Hi. We moved last year and inherited a pool. This was all new to me and I wound up replacing the liner and getting a cartridge filter. The pool is fully decked in.
I tried to get it up and running again this year but I have some leaks (had minor leaks last year as well, which apparently I forgot about until I started the pump).
I'm wondering how worthwhile it is to just use sch 40 pvc everywhere.
I already bought some ball valves which so I can cut the water off if needed and to fill pump basket.
Since things are leaking (mutliole leaks, all at the connections between the flexible hose and the adapter) I was now planning on replacing all the hose clamps, and all the hose adapters and redo basically everything just keeping the hoses seen here.
Then i wondered if I'd be better off just upgrading to full PVC.
I feel I won't have to worry about leaks and I'll have a more efficient system. However I'm not sure if it makes sense.
Don't mind the mess, but below is the setup as of now. I just have the 1 return in the pool. I also have a solar panel (came with the pool but was never used. I haven't read great things so I'm debating if it's even worth the effort to install) and I was considering adding a PVC sprinkler.
For now I planned on just doing a bare minimum set up with some unions so i can do the add-ons later.
Thoughts on pro/cons of PVC vs trying to make the current set up work?
People seem to have luck with this piping and hose clamps, but Im not. I'm not sure if the the plumbing is just getting old or what.
Thanks!
Thanks!
