Hi, I'm a soon-to-be pool owner. Installer plans to install a Jandy JXi 400N without Versaflo bypass. He doesn't know anything about it, and doesn't see any reason to incur the extra cost. He says the cost difference is about $600. Supply house says they don't sell very many with the bypass. I've been researching and I think I may still want it. What do you think? Has anyone tested what the difference in flowrate is achieved when the bypass is active vs inactive? It seems to me that's where the energy savings can come from, i.e. set the VS pump to pump a certain speed to achieve desired pool turnover with bypass active (i.e. bypassed) rather than with all flow going thru heater. If you assume the heater-active time is minimal, then you will still get the pool turnover you want, at a lower RPM than you'd use if it was never bypassed. Lower RPM then means less KWH.
Is my thinking correct? Does anyone have any actual flowrate numbers? I don't know how to use PSI differences, since I plan to set the pump speed using flowrate.
Regardless, do you think the versaflo is worth it?
