My pool area tends to get flooded when it rains heavily and too many times I was out there at night with a flash light switching on my mechanical pool timer (getting shocked several times) and opening those valves to pump out the pool. As I already was using Home Assistant for several things I decided to automate my pool at the lowest cost possible.
Bill of materials:
Still a lot more ideas for more automation, this is why I have a lot of space in my junction box for more SONOFFs. E.g. there will be more valve actuators for robot mode, bubble mode, etc. Thinking about measuring chemicals too. But I haven't heard about a low cost option yet.
Let me know what you think!
TruWolf
Bill of materials:
- 2 x TPE24VA from ebay, roughly $50 a piece
- 1 x Enbrighten 40Amps switch @ $130 (this is the most expensive piece of my setup)
- 1 x Sonoff 4CHPRO @ $35
- 120V to 24V transformer @ $25 for the actuators
- Outdoor junction box @ $90 (sized it a bit bigger as I have more automation ideas)
- older Samsung tablet from ebay @ $90
- Yolink water temperature sensor @ $35
- various cables, boxes, etc
- hidden wall mount incl. power supply for tablet @ $23 (Makes by Mike)
- automated pool timer (pump) on 9am, off 5pm
- manual on or off if needed at night
- "drain for 2 minutes", "drain for 5 minutes"
- turn drainage valve open, close after 2 or 5 minutes
- switch valve from "Waterfall" to "Spa" and back
- various ZWave light switches for light string and underwater pool and spa lights
- pool and spa light is LED and switches to "next mode" when "double clicking" (different colors, blinking, etc)
- water temperature display
TruWolf
