Scale or calcium build up on pool surface question
spikefootball
1
Miami,FL
Emptied my pool ( because od the very rough surfaces. Looked like what they call scale or calcium. Have to redo my pool pump from all the grit that it sucked up
Acid sprayed it. Then used a 3600 psi pressure washer on every inch.shoveled out the grit which looked like beach sand. Probably enough to fill 3 or 4- 5 gallon buckets.
MUCH BETTER,, looks like new, but not perfectly smooth. Still a little rough, but i can live with it. Is it OK a little rough? Or does that mean it will still come loose over time? Should I get a tool to smoothen it more?
Any other steps before filling it?
