Hi, everyone.
I've been following the Trouble Free Pool philosophy since we renovated our pool in April 2024. Indeed, our pool has been trouble free, but I'm still wondering why the pH wants to settle around 8.0 or 8.1.
We re-plastered our 12,500 G salt water pool 10 month ago with a Pebble-Tec like product. Various sources on the TFP website indicate that the ideal pH range is 7.6 to 7.8 for a plaster and salt water pool like mine. In order to maintain this level, I need to add about 4 oz of muriatic acid every other day. I was under the impression that it was the new plaster that was driving the pH up, but that this effect would diminish over time. After 10 months, I don't really see much change.
I'm writing because I hired a local pool company to help me with an equipment issue. The technician struck me as experienced and knowledgeable, so I asked him about my pH levels. He said that salt water pools typically have higher pH levels and that I should try to maintain a pH of 8.0 or less and only add acid if the pH rises to 8.1 or more.
How does this community react to my technician's statement? I have a feeling that most people will strongly advise that I stick with TFP's recommendation: 7.6 to 7.8. That's fine, but I would respond with the following question: During the winter months, when no one swims, the water temperature is about 55 degrees. At a certain chemistry level, if the pH is 8.1, my CSI is -0.070. If I drop the pH to 7.7, the CSI drops to -0.450. During the summer, the water temperature is about 80 degrees. A pH of 8.1 yields a CSI of 0.160 and a pH of 7.7 yields a CSI of -0.220. So why am I constantly adding acid to fight rising pH levels when higher pH levels seem to be desirable?
Thanks for your help on this.
bP
Cl 4.5
cc 0.0
pH 8.1
TA 65
CYA 70
CH 400
Salt 2800 (I know this is low, but the SWG isn't creating Cl right now)
CSI -0.050
bP
Cl 4.5
cc 0.0
pH 8.1
TA 65
CYA 70
CH 400
CSI -0.050
