I would appreciate help in trying to understand/figure out this cya/FC levels. We bought a home recently with an above ground 6000 gallon Polygroup Summer Waves vinyl pool. The filter/pump is attached to the side of the pool with the inlet at the same level as the return at approximately water level. The filter is a cartridge A or C purchased locally.
So after all of that, I just went through a bout of combating cloudy water. After finding this site, I stopped using the stabilized tablets and switched to household bleach. I purchased a “strip” test that would give me a ball park of my CYA level: it’s somewhere around 70 ish. With the CYA/FC chart I need to keep my FC around a 6. My water is clear, but my concern is the safety of swimming in a pool with chlorine at that level. I realize that doing a partial water exchange is needed to bring the CYA down, but need to plan for that and would like to know about the safety of running the higher levels until the exchange can happen. Thank you in advance for the help.
