- Aug 5, 2024
- 6
- Plaster
- Hayward Aqua Rite Pro (T-15)
Hi All,
Model: P-M267AEN-C
Serial: 0701192652
Heater suddenly started showing code CLK occasionally. When powered on, the display goes through the normal CFH, and then SPK, but instead of firing, I sometimes get CLK. I cleaned all heater parts including manifold gas injectors and made sure pool filter is clean and water pressure is within limits.
I tapped the front controls and CLK code went away. I then reset all connectors on the system board and heater worked for a number of hours. But after a while, the CLK came back.
Doing a bit of research online, the CLK code is normal if there is a "fireman's switch" installed to cool down the heater prior to the pump going off. However, I do not have this installed. The pump works on a normal mechanical timer.
Pressure sensor? Bad Board?
Any suggestions greatly appreciated.
Model: P-M267AEN-C
Serial: 0701192652
