- Sep 7, 2015
- 4
- Vinyl
- Pentair Intellichlor IC-40
Hi, I've had an intellichlor ic40 since my pool was installed about 6 years ago. Starting towards the end of last season, it seemed to struggle to produce enough FC for the first time. I've been adding liquid chlorine from time to time to compensate and run it at near 100%, with the pump on from 7am to 10pm. The lights are all normal. This has continued so far this year and it also now routinely over states the salt level (about 4000 vs 3400 using test kit). So I've been looking for a new one. I have the power center and everything else Pentair already so probably going to stick with getting a new cell. However, I'm having trouble determining if there is a difference between these 2 listings on Leslie's. One says 'limited warranty' and the other 'pro grade premium warranty'. But both descriptions say 2 years. Any ideas on the difference if any?
lesliespool.com
lesliespool.com
Thanks
Mike
Pentair IC40 IntelliChlor Replacement Salt Cell - Chlorine Generator | Leslie's Pool Supplies
The Pentair IntelliChlor IC40 Chlorine Salt Cell uses common table salt to produce all the chlorine a pool needs, safely, effectively and automatically.
Pentair 520555 Replacement Salt Cell | Leslie's Pool Supplies
The Pentair Salt Cell is made for use with the Pentair IntelliChlor IC40 Chlorine Generator system. Includes a 15 ft cable and sanitizes up to 40K gallon pool.
Thanks
Mike
