When Replacing seal between coping and deck, can Crack-stix be used for this application. Salt water pool if it matters.
thanks
thanks
Crackstix is for asphalt, not concrete.When Replacing seal between coping and deck, can Crack-stix be used for this application. Salt water pool if it matters.
thanks
There is a concrete version.Crackstix is for asphalt, not concrete.
Crackstix is available for concrete and asphalt jointsCrackstix is for asphalt, not concrete.
Still have to take a blowtorch to make it set I assume? I guess that works, assuming the deck or coping isn’t painted.There is a concrete version.
125ft. Crack•Stix ½” Gray Permanent Joint & Crack Filler
If it is not flexible then it is the wrong product for an expansion joint.Still have to take a blowtorch to make it set I assume? I guess that works, assuming the deck or coping isn’t painted.
It says it’s elastomeric, so assumed it was flexible. Still not sure I’d use it near concrete as I’ve had air pockets in concrete explode when touched with a blowtorch. Not really worth the risk IMO if there are other products that work as well.If it is not flexible then it is the wrong product for an expansion joint.
yep, blowtorch activated.Still have to take a blowtorch to make it set I assume? I guess that works, assuming the deck or coping isn’t painted.
