Hello all,
After 2 years of having my system, I had the nipple on my ozone system break. I had decided when the system stopped working I was going to remove it. I capped the nipple, and disconnected the ozone generator. But here on the return is the Venturi device. I want to remove the setup from my plumbing, but I am unsure if I need a one way valve or not. As you can see on my spa return there is a one way elbow. Can I just remove the Venturi and replace it with 2” pipe? Or should I add a one way clapper as well on the pool return?
Thanks for any help!
