- Sep 15, 2021
- 7
- Plaster
- CircuPool RJ-45
Hello! I recently have been doing a deep dive into my homes electrical usage and came to the quick conclusion that my pool pump is by-far the biggest culprit for most usage over time. When running it pulls nearly 8A, close to 1800W. This is wayy to much and costs me nearly $2/day, in non peak hours. Because of this, I am looking into getting a Variable Speed Pump and looking for recommendations from the community. I currently have a Pentair Superflo Single Speed 1.5 HP.
Ideally would like to break even on cost within 2 years, which i think is do-able. Research on the forum tells me that around 1100 RPM is a good setting to be at for my pool size. I think this would drop my usage down to about 1-2 A, which is dramatic savings. I like the idea of being able to control the rate which is why i'd prefer Variable over 2 speed.
I just installed the Circupool SJ-45 SWCG this past weekend and am happy with it. Because of that, I was thinking the CircuPool SmartFlo Variable Speed Pool Pump - 1.5 THP. I like this option because it is much cheaper than the Pentair one and it has an additional module that is available to integrate with automations.
I will DIY the install and ideally would like a drop-in install, but if not then its not the end of the world.
Thanks!
*The below graph is my current usage, a combination of the Pump and the SWCG loads.
Thanks!
